It is currently Thu Nov 26, 2026 8:31 am
 Post subject: carter bbd rebuild
PostPosted: Thu Jun 22, 2006 2:17 pm
Car Model: 1967 Dodge Dart GT
i got my super six on and its running a little rough around 55-60, and its guzzling worse then it should be i hope, reviewing old messages, most people who put on a super six experienced this and then rebuilt, so i got a kick from napa, for the right year of the donor car, and it has two instruction sheets,one says 1 1/4 solid fuel and the other says with duty cycle solenoid, which do i need to follow? the donor car was a 77 volare wagon, i rebuilt my 1920 before, but any tips of special things to watch for on a bbd? thanks
PostPosted: Thu Jun 22, 2006 2:26 pm
Yours is the 1½" "solid fuel" BBD, not the one with duty cycle solenoid. Nothing particularly special to watch out for on the BBD when rebuilding; they're pretty easy to put together. Take your time, keep everything clean-clean-clean, and double-check the instructions if you're not sure about something.
PostPosted: Thu Jun 22, 2006 3:03 pm
Watch out for worn thorttle shaft bushings!
PostPosted: Thu Jun 22, 2006 3:39 pm
where exactly are they and i think i read somewhere about brass replacement ones coming with a rebuild kit?
PostPosted: Thu Jun 22, 2006 4:19 pm
Teh throttle shaft bushings are located around the throttle shaft where is passes through the carburetor body. I have never seen a reuild kit that included new bushings, but any competent machine or carb shop should be able to rebush the carb.
PostPosted: Fri Jun 23, 2006 7:56 pm
can anyone with a working bbd supersix take a picture of how the little piecs are all supposed to go in the little compartment on top? three screws take the cover off, then what i think are the metering rods, and a couple other things i dont know the technical name for, i didnt take a picture before i took it apart and my instructions are garbage, its just a exploded diagram, a poorly drawn and detailed one at that...thanks
PostPosted: Sat Jun 24, 2006 8:31 am
the little cross shaped piece wont go down like it should, and the range of motion is too smail i think when i force it, the white piece goes to high and over the top of the spring that controls how much fuel comes in, anyone?
Users browsing this forum: Google [Bot] and 7 guests
