It is currently Thu Nov 26, 2026 5:22 pm
 Post subject: 225 rods
PostPosted: Sun Jun 25, 2006 5:30 pm
Are the 225 rods interchangable thru the years? If you are using the
early steel crank 225 you need the same rods from that era to match right? And the cast crank 225 uses the rods that are correct for it,right??
PostPosted: Sun Jun 25, 2006 5:41 pm
Forged cranks only fit forged crank blocks as the cast cranks fit late blocks and yes, the rods are different.
PostPosted: Sun Jun 25, 2006 8:27 pm
All the forged steel crank, 225 con rods are the same, 1960 thru 76 and carry forging number 2205554
The cast crank con rods are different, these are narrower.
Users browsing this forum: Ahrefs [Bot] and 9 guests
