It is currently Tue Nov 17, 2026 12:17 am
PostPosted: Mon Jun 26, 2006 6:01 am
Does anyone know the correct torx wrench size for the fluid fill/level check hole in the 7 1/4" rear? I didn't know they had torx in '63.
PostPosted: Mon Jun 26, 2006 6:09 am
Should just be a 1/2" socket drive.
PostPosted: Mon Jun 26, 2006 7:38 am
Yeah, that's not Torx, it's just a "double square" 8-point socket-head plug. I use a 3" length of ½" bar stock from the hardware store, clamped in a Vise-Grips.
PostPosted: Mon Jun 26, 2006 9:15 am
OK. Good deal. Thanks much. Then that probably would be the same thing for the oil galley plug at the back of the engine block (wish I would've asked sooner).
PostPosted: Mon Jun 26, 2006 1:49 pm
Oil galley plugs are 5/16 allen head or square
