It is currently Fri May 15, 2026 10:30 am
PostPosted: Mon Oct 08, 2001 10:18 am
What are the tooth counts for slant 6 starter pinons and flywheel ring gears? I want to know, because I'm looking for an easy swap / fix for my straight "L" six (either a 236 or 251).
derekacomb@hotmail.com
PostPosted: Tue Oct 09, 2001 7:59 pm
: What are the tooth counts for slant 6 starter
: pinons and flywheel ring gears? I want to
: know, because I'm looking for an easy swap /
: fix for my straight "L" six
: (either a 236 or 251).
All gear reduction Mopar starters have 10 teeth.
The SL6 flywheel for the 10" clutch (and 9 1/4) has 122 teeth.
There is no way a SL6 Bellhousing is going to bolt to your flathead L six, the starter is up to high. I think a V8 bell with an adaptor plate works.
