It is currently Fri May 15, 2026 12:59 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 6 posts ]
 Post subject: Which ATF for A904?
PostPosted: Mon Oct 08, 2001 3:51 pm
Which transmission fluid should I use? My '64 904 just got back from a rebuild and I've almost got her reinstalled in my daily driver /6 '64 Valiant. The book calls for Type A (still available), the instructions with the transmission say Dexron II for all Chrysler transmissions, and Dexron III was all I saw at the two parts stores I checked.
dobie79423@yahoo.com
 Post subject: Re: Which ATF for A904?
PostPosted: Mon Oct 08, 2001 8:38 pm
: Which transmission fluid should I use? My '64
: 904 just got back from a rebuild and I've
: almost got her reinstalled in my daily
: driver /6 '64 Valiant. The book calls for
: Type A (still available), the instructions
: with the transmission say Dexron II for all
: Chrysler transmissions, and Dexron III was
: all I saw at the two parts stores I checked.
I have used only type F in mine since I rebuilt it
4 years ago. The Dextron will not have as high a co-efficient of friction as the type F and you will get a smoother shift out of it, but using type F you will get a little bit more of a snap out of the shifts. the best part is if you don't like the way either one performs just change the fluid.
dbjerklund@hotmail.com
PostPosted: Tue Oct 09, 2001 12:08 am
Type F is the way to go
Will
slantsix@netzero.net
PostPosted: Tue Oct 09, 2001 9:25 am
: I have used only type F in mine since I rebuilt
: it
: 4 years ago. The Dextron will not have as high
: a co-efficient of friction as the type F and
: you will get a smoother shift out of it, but
: using type F you will get a little bit more
: of a snap out of the shifts. the best part
: is if you don't like the way either one
: performs just change the fluid.
You can use Dextron III from the parts stores, or Type F. Fopar is right about the trends.
madsenl@caltech.edu
PostPosted: Tue Oct 09, 2001 3:55 pm
: You can use Dextron III from the parts stores,
: or Type F. Fopar is right about the trends.
: Lou
I used some B&M high performance stuff in my Diesel truck which gave me a nice firm shift. Its blue in color and seems thinner than the red stuff we all are used to. I dont know if it is any good in a Torque Flight. Anyone have any experience with this stuff??
MrSlant@pacbell.net
PostPosted: Tue Oct 09, 2001 6:13 pm
: I used some B&M high performance stuff in my
: Diesel truck which gave me a nice firm
: shift. Its blue in color and seems thinner
: than the red stuff we all are used to. I
: dont know if it is any good in a Torque
: Flight. Anyone have any experience with this
: stuff??
Trick Shift is basically Type F fluid with blue dye instead of red.
aschumers@aol.com
