It is currently Mon May 18, 2026 9:48 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Post subject: Rocker Slippage
PostPosted: Tue Oct 09, 2001 12:29 pm
Hello,
I have a '63 slant 6 with a #5 rocker arm that slipped on its axis such that the arm disengaged from the valve and pushrod. I have never adjusted the valves. Is this disaster a result of loose valve adjustments? Any suggestions would be helpful before attempting to reposition the rocker arm.
regards,
Dan
dkalcic@mail.arc.nasa.gov
 Post subject: Re: Rocker Slippage
PostPosted: Tue Oct 09, 2001 3:50 pm
: Hello,
: I have a '63 slant 6 with a #5 rocker arm that
: slipped on its axis such that the arm
: disengaged from the valve and pushrod. I
: have never adjusted the valves. Is this
: disaster a result of loose valve
: adjustments? Any suggestions would be
: helpful before attempting to reposition the
: rocker arm.
: regards,
: Dan
The old Dodge adjustable rockers do eventually wear out and wont stay in adjustment. I would try to adjust the valves at .010 intake/ .020 exhaust (for a stock cam) while the engine is hot and running. If the rocker goes out again you can get a rebuilt rocker shaft assembly from Kanter Assoc in New Jersey for about $40 or you can get the ARP long adjusters and double nut them and they will never slip. Hope this helps
MrSlant@pacbell.net
PostPosted: Tue Oct 09, 2001 4:06 pm
: Hello,
: rocker arm.
: regards,
: Dan
Loose valve adjustment, a bent pushrod, a sticking valve guide or a poorly aligned rocker to valve stem tip could cause the racker to "jump-off".
"Roll" the pushrod to make sure it is not bent, check the rocker arm side clearance and adjust as needed. (rocker shaft retainer washers)
Once everything is back together, re-torque the head and adjust the lash.
