It is currently Fri May 22, 2026 7:45 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
PostPosted: Tue Oct 09, 2001 11:09 pm
Is a 750 cfm holley to much for a /6? Will i have any problems idle,stop and go daily driving.Am I crazy to put this on my daily driver.
vicious1@hotmail.com
PostPosted: Wed Oct 10, 2001 8:22 am
: Is a 750 cfm holley to much for a /6? Will i
: have any problems idle,stop and go daily
: driving.Am I crazy to put this on my daily
: driver.
Yep, it's way too much. If you manage to make 350 HP, then maybe you can run it. Even a 600 is a bit on the big side. I have found the Edelbrock 500 4bbl works well on medium built motors, and otherwise you should go smaller than that.
PostPosted: Wed Oct 10, 2001 4:51 pm
I have a 600 dp but I run a turbo down thru it. it is okay if I do not get into th seconderies to soon.
andrew wagner
: Yep, it's way too much. If you manage to make
: 350 HP, then maybe you can run it. Even a
: 600 is a bit on the big side. I have found
: the Edelbrock 500 4bbl works well on medium
: built motors, and otherwise you should go
: smaller than that.
: Lou
