It is currently Sat Nov 21, 2026 5:27 pm
PostPosted: Wed Jun 28, 2006 12:44 pm
When I pulled the axles from a '64 7 1/4" rear, I noticed something. The axle seals on both sides of the car were installed with the lip (concave) side out, so you could see them.
(New seal pictured. The old ones got mangled a bit on the way out)
The flat faces were inboard.
That ain't right, is it?
By the way, they did not come out easily. One had been leaking a bit.
PostPosted: Wed Jun 28, 2006 12:59 pm
Oops! Meant to put this in the Transmission and Rearend section.
PostPosted: Thu Jun 29, 2006 7:45 am
Yep, flat side out. :shock:
PostPosted: Thu Jun 29, 2006 5:46 pm
I want to pull the left rear axle on my 63 to put in right-hand wheel bolts/studs.
I don't detect any unusual noises from the rear axle.
Can I just replace this seal, or are there other parts to renew?
