It is currently Tue May 19, 2026 7:37 am
PostPosted: Thu Oct 11, 2001 8:51 am
Hi Everyone,
Quick question.. I have acquired a set of 10" drums (complete package of spindles, backing plates, drums, cylinders,shoes and brake hardware) to put on the front of a 66 Dart with 9" drums. I'm getting conflicting information as to whether I need to get different Upper Control Arms or I can use my existing UCA's..??? Can anyone give me quick answer...!! :) Thanks
66Dart
PostPosted: Thu Oct 11, 2001 1:05 pm
: Hi Everyone,
: Quick question.. I have acquired a set of
: 10" drums (complete package of
: spindles, backing plates, drums,
: cylinders,shoes and brake hardware) to put
: on the front of a 66 Dart with 9"
: drums. I'm getting conflicting information
: as to whether I need to get different Upper
: Control Arms or I can use my existing
: UCA's..??? Can anyone give me quick
: answer...!! :) Thanks
: 66Dart
I believe it depends on the YEAR of the 10" drum spindles. If they are off a pre-'73 Dart (or any A-body), then you can use your '66 UCAs. Otherwise, I don't think so, but I'm not positive. Personally, I would skip the 10" drums and go for discs...
PostPosted: Thu Oct 11, 2001 1:16 pm
: I believe it depends on the YEAR of the
: 10" drum spindles. If they are off a
: pre-'73 Dart (or any A-body), then you can
: use your '66 UCAs. Otherwise, I don't think
: so, but I'm not positive. Personally, I
: would skip the 10" drums and go for
: discs...
: Lou
I agree with Lou, the UCAs are the same for 72 and earlier 10" set-ups. (non-"finned" drums)
PostPosted: Fri Oct 12, 2001 5:35 pm
A different topic, but has anyone every attempted using AMC drums ?
<A HREF="http://www.moparmuscleclub-sa.org/Tech_ ... att.htm</A>
: I agree with Lou, the UCAs are the same for 72
: and earlier 10" set-ups.
: (non-"finned" drums)
: DD
http://www.moparmuscleclub-sa.org/Tech_Articles/boltpatt.htm
tkeith@mindspring.com
