It is currently Thu Jun 18, 2026 12:28 am
 Post subject: Holley-Weber connection
PostPosted: Fri Jun 30, 2006 8:24 am
What would that big tube at the left connect to. The valve cover?
PostPosted: Fri Jun 30, 2006 8:51 am
My guess would be the charcoal cannister. Looks alot like a fuel bowl vent.
PostPosted: Mon Jul 03, 2006 3:12 pm
I have two similar webers
The fuel inlet is on that part just above the big tube.
One of mine has the fuel inlet and the vent tube coming off that part.
Are there one or two tubes coming off the part above it?
If not, it could be the fuel inlet because it's in the general area.
PostPosted: Mon Jul 03, 2006 5:41 pm
I found these that almost help.
The black hose at upper left would appear to be the fuel line. A plugged red hose is obviously closing off something pretty big. The "thing" at upper right has nothing attached.
There is now a red hose attached to the "thing." Is that another plugging device? I can't tell for sure.
The carb (used) is on its wayand will almost certainly have no documentation.. Being a Holley Weber 5210 it isn't that easy to find details about. :( But I'm workin' on it.
Thanks
PostPosted: Mon Jul 03, 2006 6:05 pm
Give that man 10 silver dollars and a Mars candy bar!
On the 4th exploded view download I got one that showed it was the bowl vent. (The others didn't show it at all.) I guess not having a canister ('65 Valiant 100) I'll just plug it?
Thanks
PostPosted: Mon Jul 03, 2006 6:39 pm
Mines an 85' without one (supposed to, but hey what-can-I-say you know what I mean? wink,wink) :shock: Yes just plug it.
PostPosted: Wed Jul 05, 2006 5:28 pm
Thanks
PostPosted: Wed Jul 05, 2006 5:48 pm
Hm... it would seem to me that if you plugged it, that would eliminate the venting feature of the carb after the engine is shut off. I assumed that would be undesirable. Until I get my charcoal canisters hooked up, I just have mine venting to open air. Is this not advisable?
Used to own:
'82 Dodge D150
Erson 270 Cam, O/S valves, mild port work, ~9.5:1 compression
Currently fighting with an '85 VW Cabriolet
My other passion
PostPosted: Wed Jul 05, 2006 6:04 pm
Car Model: 63 Dart 81 D150
how about "plugging" it with a piece of hose and a cheepo fuel filter?
