It is currently Tue Nov 17, 2026 12:05 pm
 Post subject: 7.25 gear lash...
PostPosted: Fri Jun 30, 2006 3:07 pm
What is needed to setup the gear lash on my 7.25 rear???
PostPosted: Fri Jun 30, 2006 6:07 pm
1960 - 70 use shims to adjust the 'backlash', after 1970 there are 2 adjuster screws that you need a special tool to turn. (a C- body torsion bar works)
Is this a new set of gears or are you readjusting a used set of gears?
PostPosted: Sat Jul 01, 2006 6:54 am
This is a new set of gears placed in the rear recently. The rear is a 7.25 SG (cone type)from a '73 or 74 Dart sport. Trying to get the roar out of it....
PostPosted: Mon Jul 03, 2006 10:46 am
It sounds like you need to reset the pinion depth and then reset the backlash.
What is the gear contact pattern telling you to do?
Gear Contact Patterns
http://www.motivegear.com/tech_info/R_P ... tions.html
