It is currently Sat May 16, 2026 2:19 am
Post new topic  Reply to topic  [ 56 posts ]  Go to page Previous 1 2 3 4
PostPosted: Thu Jun 29, 2006 7:07 pm
Does the T5 come with several different bearing retainer diameters? If so, where can one find them listed?
PostPosted: Fri Jun 30, 2006 11:34 am
Hey Lou, FYI I received the bellhousing today. Looks great! For those considering getting in on the group buy last minute, I can tell you that the workmanship looks first-rate! I'm really pleased with how it came out.
Thanks again for all of your hard work on this, Lou. The check for the balance is in the mail!
Now if I could just figure out what I've bought... :) Kidding! Take your time on that article, Lou. I'd imagine I'm at least a year or so away from being able to afford the conversion, and the 8 1/4" rear-end swap I'll end up performing at the same time.
(Any sources for a flywheel cover?)
Thanks!!!!!!!!!!
VM
 Post subject: got it
PostPosted: Fri Jun 30, 2006 3:25 pm
Yes!...I got mine yesterday....thanks for the hard work in putting it together for us. The machine work is first rate, a very nice piece indeed! I need to order/send you the money for the spacer bushing....
PostPosted: Fri Jun 30, 2006 3:52 pm
PostPosted: Fri Jun 30, 2006 7:07 pm
4.91" bearing retainer for all T5s, as far as I have every seen.
PostPosted: Fri Jun 30, 2006 11:05 pm
Thanks
PostPosted: Mon Jul 03, 2006 6:33 pm
Lou, I got my bellhousing back today. Very pleased with the work done.
Thanks for putting this purchase together. Well worth the wait. Don
ImageImage[/img]
PostPosted: Mon Jul 03, 2006 8:38 pm
Car Model: 1962 Lancer 770
Lou, Rob and I went hunting the yards this weekend and he said he'd be fine with shipping our bells together. Thanks again for doing all this!
MJ
PostPosted: Thu Jul 06, 2006 1:54 pm
My searching of this and the .com forum have failed me in determining what needs to be done to get an accurate reading for a speedometer mated to the T-5? Lou, Sandy what did you guys use for an adapter for the speedo cable to the tranny?
Also, the v-6 t-5 failed so I am getting a v-8 GT tranny so that is the adapter I will need for the crank.
Brian
PostPosted: Thu Jul 06, 2006 5:10 pm
Does the T-5 clear the T-bar crossmember? Or do you have to hack it up?
70 Dart, 360, 727
PostPosted: Fri Jul 14, 2006 1:28 pm
Lars - Hacking required, yes.
Bohmer2 - I had a custom speedo cable made (Keisler or speedo shop) with a T5 end and a 64 Dart speedo end. Any combo can be made. Will do on the ring.
Menko - Rob should already have his - sorry but I needed it gone due to moving from NC to VA. Wouldn't have saved more than $10 or so anyway.
Don - thanks for the pics!
