It is currently Fri May 08, 2026 4:33 pm
PostPosted: Sat Jul 01, 2006 8:46 pm
Hi,
Have a 225 in my Australian truck. The truck has been sitting in my garage and been having various things done to it over the past year.
When I stopped starting teh truuck and moving it around it was running fine.
Now, it will not start. I have been through the wiring and it all seems correctly wired.
The problem is that I have about 5v at the coil when cranking, obviously inadequate. I am managing to get a spark out of it, and it is hitting occasionaly ona cylinder, but won't catch.
The ballast resistor, coil, plugs, cap and rotor are all new (but been sitting for a while with the rest of teh truck).
Now, regarding teh ballast resistor, this is a points system with a single ballast. Is there supposed to be a source of switched 12v that bypasses the ballast when cranking, to fatten up voltage to the coil? I have around 6v coming out of the ballast on teh coil side and about 8v coming into the ballast. I should have around 12v at the other side of the ballast?
Regards, Andrew.
 Post subject: First of all.
PostPosted: Sun Jul 02, 2006 1:51 pm
That's a problem. You should have a good 12v into the ballast. You'll need to trace wires until you find the short or weak connection.
There is on the models that I own, (see my signature below) but I don't know the specifics of your truck.
1980 Aspen 225 super six
PostPosted: Sun Jul 02, 2006 10:17 pm
Thanks, kind of confirms things for me. I haven't spent a lot of time with points, I grew up with Chryslers electronic ignitions.
Regards, Andrew.
