It is currently Fri May 15, 2026 3:51 pm
 Post subject: line lock e-brake.
PostPosted: Wed Jun 28, 2006 6:55 pm
I took the e-brake off my Dart when I put the 4 wheel disks on it. Someone mentioned to me that it is possible to install an e-brake that is essentially a line lock, like they do for the front during burnouts.Has anyone heard of this.? I dont; know how a line lock works. I dont; know if it is mechanical, or electrical. But the lowdown on this is that you use the hydraulic pressure to keep the rear brakes on when parked. Sounds interesting.
PostPosted: Wed Jun 28, 2006 7:06 pm
It is electric.
I don't know anyone that has used it for an E brake.
If you apply it for a long time it's going to drain the BATT or overheat the line lock/roll control solenoid.
Will hyd pressure in a brake system mantain long periods without leaking at the calipers or wheel cylinders?
Slant Cecil
PostPosted: Wed Jun 28, 2006 7:12 pm
There have over the years been non-electric line-locks, but hydraulic parking brakes are not a wise idea. The brake hydraulics are not meant to be left in an applied position/under pressure for hours at a time, and the point of an E-brake/parking brake is to have a braking system that is independent of the service brake hydraulics. In most of those jurisdictions that still have vehicle safety inspections, a setup such as you propose will flunk the car. That's why rear disc conversions intended for street use have separate mechanically-operated parking brake systems.
PostPosted: Wed Jun 28, 2006 7:41 pm
Thanks for the feed back. it sounded too good to be true. I have GM calipers on the rears, with no e-brake. I wonder what the easiest set up would be. I would want a hadle on the floor between the bucket seats. I know there is a drive shaft type as well. Can you point me in the right direction to read about this. I eliminated tje e-brake it because the handle on the dash was in the way of other stuff I wanted to put there. As it turns out, I could put the handle back there as I routed the AC differently. I put it above the steering column, which is where it will stay.
PostPosted: Mon Jul 03, 2006 11:50 am
Lokar makes a handle that bolts to the floor like a late model if I remember correctly. You could also try to adapt a parking brake lever from a Fox Mustang (87-93).
70 Dart, 360, 727
PostPosted: Mon Jul 03, 2006 1:13 pm
Here you have to have an emergency brake(different from a parking brake) so the line loc wont work.
you might do a small disc shaft brake like the big mudboggers use:
Disc sandwiched between diff and driveshaft with small caliper mounted on the diff....applied with a separate M/C.
I used to drive a tow truck that had a Mico-loc . It was a hydraulic "lock" used as a parking brake. You flipped a lever on the dash....
