It is currently Sun Jun 21, 2026 11:52 pm
PostPosted: Mon Jul 03, 2006 2:32 pm
Hi all,
I am gearing up for my transmission swap. I would like to get another crossmember for hacking up. Are the early A body and late A body crossmembers interchangable? I am guessing not, due to the change in width, but it would simplify the search considerably.
Thanks,
PostPosted: Mon Jul 03, 2006 3:06 pm
hey man
I think that up to '72 (or '67??) all transmission crossmembers are the same (without distinction on 3 on the tree, auto or manual 4 speeds)
just my 2 cents worth comment :wink:
Juan Ignacio Caino
PostPosted: Mon Jul 03, 2006 4:04 pm
In A-bodies, the '67-up crossmembers do not interchange with the '62-'66 units. Pretty sure you can put a '73-'76 "spool mount" crossmember directly in place of a '67-'72 "block mount" crossmember, but the '67+ units are wider and have differently-spaced holes than the early units. Fairly certain '60-'61 units can be replaced by '62-'66, but haven't verified.
PostPosted: Mon Jul 03, 2006 4:27 pm
OK there's m,y confussion. Our A-bodies did come in 2 flavours only: pre-67 and post. My car is post 67 and all trans crossmembers interchange. All Kmembers do interchange as you say, dan.
Juan Ignacio Caino
PostPosted: Thu Jul 06, 2006 5:18 pm
You can swap the spool mount in place of the block mounts. I did it on my 70, swaps right out.
70 Dart, 360, 727
