It is currently Fri May 15, 2026 6:45 am
Post new topic  Reply to topic  [ 43 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Mon Feb 07, 2005 9:27 pm
See this link about posting pictures:
http://www.slantsix.org/forum/viewtopic.php?t=4434
PostPosted: Sat Feb 26, 2005 6:45 am
Update ... After looking at some video tape I seen that the car was
spinning only one back wheel. After takeing the rear end apart I found
the cones was worn bad. Now with that repaired the 60' should be good.
Also I got the nitros up and running with the 100hp shot and the next fine
day I got to try it out on the street :twisted: I can't wate ..
 Post subject: Russ' 67 dart
PostPosted: Sun Feb 27, 2005 7:29 pm
Russ
I managed to figure out how to post your pics for you
here they are
Dave
[img]http://us.f1f.yahoofs.com/bc/db7371f3_m4190891a/bc/My+Documents/Image0017a.jpg?bfsGpICBjxZMBKzy
[/img]http://us.f1f.yahoofs.com/bc/db7371f3_m4190891a/bc/My+Documents/Image0018a.jpg?bfsGpICBfkU3zHcZ
 Post subject: oops
PostPosted: Sun Feb 27, 2005 7:34 pm
looks like i didnt
try again
ahhhhhhhhhhh
now i think i got the hang of it
Cheers
 Post subject: removed
PostPosted: Tue Apr 12, 2005 5:06 pm
re:
Last edited by Russell Cable on Mon May 30, 2005 3:26 pm, edited 3 times in total.
 Post subject: Re: Head Porting
PostPosted: Tue Apr 12, 2005 7:57 pm
definitely port the head.... attention to the bowl area is A+, make the bowls nice and shape them good to match the big valves you have
Where is this "bowl" area in the port? I've read this same thing elsewhere but have not been able to find any pictures showing exactly what one is supposed to port out. Help. :?
PostPosted: Sat Apr 16, 2005 2:53 pm
I had the car out today... The trans. is working good
and the rear end is spinning 2 wheals now. The timing
is set up the carb. is ajusted
The car runs great ...From stoped I done a 86.5 foot
burn out with no nitros no brake burn..When I can
figure out the pitchres I got some good ones off the smokey
burn outs!!
 Post subject: Russel's 67 dart
PostPosted: Sun Jul 24, 2005 4:14 pm
ok
PostPosted: Mon Aug 01, 2005 3:42 pm
new time slips.
first run 15.13 ET
86.63 MPH
2.138 60 foot
#2 15.050 ET
87.22 MPH
2.154 60 foot
#3 15.042 ET
87.89 MPH
2.162 60 foot
#4 14.447 ET
90.96 MPH
2.557 60 foot
#5 14.482 ET
94.31 MPH
2.168 60 foot
So now how do I get to the 13 from hear.
The 2 runs in the 14 were on NOS but only
1/2 the track. This was the first time on NOS :?
PostPosted: Fri Aug 19, 2005 6:39 pm
Russel's dart
Think i may have it again Russ
Dave
PostPosted: Sun Jun 25, 2006 8:04 pm
Does anyone know the part # for the 490. comp cam????
PostPosted: Mon Jul 03, 2006 12:03 pm
The part # for the .490 comp cam is
64-000-5
PostPosted: Mon Jul 03, 2006 4:13 pm
Thanks Russel. What is all done to your car in terms of weight reduction?? I'd like to get my duster in the 2600 range if possible :D
PostPosted: Thu Jul 06, 2006 5:33 pm
Some of the things I did to redose
weight was to use fiber glass front
fenders, aluminum inner fenders,
fire wall,radator surport,intake manfold
and radator . Lite weight starter,and
ault.
Race seats,and Suspension. No back seat
and aluminum floors. Fiber glass bumpers
and changed most of the glass to lexan.
plus everthing that was not needed was
removed such as raido,speakers,led body
filler, ect.....
PostPosted: Thu Jul 06, 2006 5:47 pm
I noticed you have hood pins as well..this would mean fiberglass hood as well right?? thanks- Michael :D
