It is currently Sun Nov 29, 2026 8:34 am
 Post subject: Carb puzzle solved
PostPosted: Fri May 26, 2006 9:28 am
Someone said to look at Weber 5200 carbs. Some were puzzled that I couldn't find much of anything on the internet about them. Turns out altho they are Holley produced Webers, over 99% of people on the internet refer to them as Holley, not Weber.
Question remaining: I've read (also on the internet) that Holley 5200's were a "cheap knock-off" of the Webers. Comments? Thanks
PostPosted: Fri May 26, 2006 10:18 am
Cheaper in price, not cheaply constructed.
The Holley/Weber 5210 is found on 1970's GM 4cyl. cars and mostly on Vegas. The 5200 is the Ford version of this carb. The Weber version is a 32/36 DFEV or 32/36 DFAV.
I tracked my 5210 down to coming off of a 1977 Vega. I found this info out of a Chilton Auto Repair Manual 1975 through 1982. The Holley/Webber carb came out in the early 1970's
The 5200 is considerd a Ford Autolite Motorcraft Carb.(at least in this manual). From 1975-1981.
The 5210 is considerd a Holley as is the rest of the numbers below.
The 5210 included AMC 1977-1979.
GMC Chevette 1979 and 1980, Monza & Vega 1975-1978, Starfire 1976-1978, Astre, Sunbird and Ventura 1975-1978.
Numbers below are more electronic.
The 5220 is a 1978-1981 Chrysler Omni/Horizon version.
The 6500 is a 1978-1981 Ford Pinto/Bobcat.
The 6510 is a 1978-1981 GMC.
The 6145 and 6520 is a 1981 Chrysler.
Different Sites with Information on Holley/Webber Carbs
http://www.slantsix.com/UBB/Forum16/HTML/010573.html
(This site has info on putting a Webber on a Dodge 6cyl)
http://www.albertpenello.com/mustang/engine.html
(This site has info on putting a 5200 on a Ford 200 6cyl)
http://www.angelfire.com/me4/bootsnthej ... ertech.htm
(This site has info on putting a Webber on a Jeep 6cyl)
http://www.225.ca/tech/jstk002.htm
http://www.surpluselectron.com/aaron/holley.htm
http://www.carburetion.com/carbinf.htm
http://www.webercarbsdirect.com/technical_information
82 D150 Slant6 Shorty
http://www.cardomain.com/ride/658846
PostPosted: Fri May 26, 2006 11:26 am
Yes, and to expand on this:
Chrysler produced cars/trucks til 1987/1988 respectively with these 5220/6520. Depending what they got, early TBI was offered starting in 84-85-ish as a OPTION and offered on very few models.
I have 5220 on 2.2L in 1987 plymouth caravan. Works ok, long as it's hard starting variety rather than easy start/ crummy running. :wink:
After 87/88 all chrysler cars/trucks got injection of any form TBI or MPI.
Cheers, Wizard
PostPosted: Fri May 26, 2006 1:33 pm
Thanks
PostPosted: Fri May 26, 2006 1:34 pm
Cheers, Wizard
Thanks
PostPosted: Fri May 26, 2006 5:29 pm
Cheers, Wizard
Minor nitpick- the 1989 M-bodies (5th Avenue, Gran Fury, Diplomat) were all still carbureted IIRC.
PostPosted: Sat May 27, 2006 12:48 pm
I forgot to add my own. http://www.cardomain.com/ride/658846/5
PostPosted: Wed Jul 05, 2006 11:22 am
I think I bought an earlier version of the 5210 (haven't received it yet). I'm almost certain I'll need to rebuild it. And I'll need a choke. How do you locate parts for these? I had assumed that Weber suppliers would have them if you knew which numbers to ask for.
Thanks
BTW, the web site says the Weber version is DFEV/DFAV. Aren't F's for Fords?
PostPosted: Wed Jul 05, 2006 11:59 pm
I got all my parts from the parts store. Just get a kit for an early Chevy Vega, maybe 1975. My electric choke is for a 1980 Ford Pinto.
The "F" I don't believe it means Ford. The "E" is for electric choke and the "A" is for a water choke.
PostPosted: Thu Jul 06, 2006 4:42 am
I think my '73 Mercury Capri V6 2.6 L had a holley/weber 5200 and it was referred to as a "progressive" 2 barrel meaning that it was like half of a mechanical secondary 4V, running on 1 barrel until you pushed the throttle down. FWIW.
PostPosted: Thu Jul 06, 2006 7:13 am
Makes sense. Thanks.
PostPosted: Thu Jul 06, 2006 7:51 am
Pat, that would be correct!
 Post subject: cfm rating?
PostPosted: Fri Jul 07, 2006 11:19 pm
Anybody know the cfm rating of these carbs?
I just remember the inconsistant idle speed/ quality that they are notorious for in the Volkswagen air cooled world. I never had any similar problems in a 2.3 ford app. Have had both weber and holley castings on 2.3's, same carb and respond well to tuning!
If the cfm rating is slightly higher than a bbd, It should make a good swap in my eyes as I am fairly familiar with em, and my app is with a manual trans, so no kickdown worries. Thanks in advance!
Bill
Update...I answered my own question.
220 cfm bbd vs 280 cfm holley weber....hummmm.
If ya haven't been there, you just wouldn't understand.....
My friends and I spent a LOT of money in the eighties to get me this way!!!!
PostPosted: Fri Jul 07, 2006 11:38 pm
The majority are rated at 280 CFM (same as a Carter BBD) but some models are lower. 210 I think.
PostPosted: Fri Jul 07, 2006 11:43 pm
I got the bbd rating from the 1bbl vs 2bbl topic...
Just wonder if it would be worth the trouble.
Bill
Users browsing this forum: Bing [Bot] and 8 guests
