It is currently Wed May 13, 2026 8:13 am
 Post subject: Original brakes?
PostPosted: Fri Jul 07, 2006 8:56 pm
What kind of brakes should one expect to find on an original '72 Challenger?
PostPosted: Fri Jul 07, 2006 9:06 pm
Hydraulic.
PostPosted: Fri Jul 07, 2006 11:00 pm
If you are asking disc or drum fronts, my 72 has drums all around. But there were options for disc fronts.
PostPosted: Fri Jul 07, 2006 11:18 pm
So this is the treasured E-body brakes A-body Slanters used to dream about . . . :wink:
Thanks
PostPosted: Fri Jul 07, 2006 11:19 pm
Hydraulic.
Ever the optomist.
PostPosted: Sat Jul 08, 2006 5:38 am
Actually, since there were far more a-bodies and the 73 up disc brake spindles work on either an a- or e-body most e-body guys grab the later a-body disc parts for up front.
PostPosted: Sat Jul 08, 2006 8:02 am
Perhaps I misunderstood some things I've read. As I said, I was referring to Slanters - but I meant A-body Slanters. V_8 owners, especially with larger bodies, obviously want discs.
PostPosted: Sat Jul 08, 2006 5:42 pm
I seem to have left out a detail. What prompted this thread/question was finding 10" front drums on a '72 Challenger. As of now I can't even find anyone who sells replacement 10" front drums.
I don't know for sure, but I'm guessing the Challenger actually delivered with a 225 in it.
Thanks
PostPosted: Sat Jul 08, 2006 5:47 pm
Did you try RockAuto?
PostPosted: Sat Jul 08, 2006 5:51 pm
Yup. They have 10" rear and 11" front.
Thanks
PostPosted: Sat Jul 08, 2006 5:54 pm
Go here:
http://www.federalmogul.com/aftermarket ... ountry=USA
Then under Catalogs, Make Model lookup....
Get a part number(s) then enter that part number at rock auto under part(s) number lookup.
Sometimes you can find stuff at rockauto that way........... (they don't always have everything crossreferenced....)
PostPosted: Sat Jul 08, 2006 6:29 pm
Go here:
Thanks
Well, horse feathers - and a side dish of chicken hair. Nice place and lots of fun, but they didn't have any drums listed, only studs, nuts and shoes - and info about when t o throw the drums away away, etc. (And I tried on each side of 1972.)
Thanks
PostPosted: Sat Jul 08, 2006 7:07 pm
Car Model: 63 Dart 81 D150
in this book
http://i61.photobucket.com/albums/h56/t ... C00002.jpg
it says 10 x 2 1/2 front brakes were avaible
the part # BD60264 is listed for front drums.
though they dont list diffrent #s for each side
the same # is listed for a base 72 charger with 10 x 1/2
REMEMBER this is a 1989 parts book. but that # might help you in your search. the parts did exist at one time. someone may be able to convert that # for you to something.
good luck
PostPosted: Sun Jul 09, 2006 7:29 am
in this book
good luck
Every little bit helps.
Thanks
