It is currently Mon May 18, 2026 9:07 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
 Post subject: Mounting Degree Wheel
PostPosted: Sun Oct 21, 2001 9:36 pm
What is the best way of mounting a 7" Mr. Gasket degree wheel on a Slant 6 and any comments on competition cams 264 camshaft would be appreciated. Thank you.
lauchlin@shaw.ca
PostPosted: Mon Oct 22, 2001 8:15 am
: What is the best way of mounting a 7" Mr.
: Gasket degree wheel on a Slant 6 and any
: comments on competition cams 264 camshaft
: would be appreciated. Thank you.
See
<A HREF="http://hackme.dhs.org">http://hackme.dhs.org</A>:8080/pics/degree/
I took pics of mine mounted.
from the side
cralt@hackme.dhs.org
PostPosted: Mon Oct 22, 2001 12:46 pm
That is the best way to do it. Although you could get away with drilling the center and using a crank bolt with a rubber washer. The 3 bolt method is the best.
I degreed in my Comp Cams 252S Saturday, and found that the Cloyes Double Roller chain and sprockets I purchased from NAPA had mismarked "dots" stamped on them. After the initial degreeing I had to run over to my friends and drill press my cam gear and use the Mopar Bushing set I got (used the 4 degree bushing) to get it within spec.
res0aus2@verizon.net
PostPosted: Mon Oct 22, 2001 8:22 pm
D.I.
Do you have a part number for the NAPA/Cloyes chain and sprocket set?
Charlie
: That is the best way to do it. Although you
: could get away with drilling the center and
: using a crank bolt with a rubber washer. The
: 3 bolt method is the best.
: I degreed in my Comp Cams 252S Saturday, and
: found that the Cloyes Double Roller chain
: and sprockets I purchased from NAPA had
: mismarked "dots" stamped on them.
: After the initial degreeing I had to run
: over to my friends and drill press my cam
: gear and use the Mopar Bushing set I got
: (used the 4 degree bushing) to get it within
: spec.
: -D.Idiot
flturbo6@aol.com
