It is currently Sun Nov 29, 2026 11:34 pm
PostPosted: Wed Jul 12, 2006 9:18 am
Someone recommended the NGK ZFR5N plug with gasket removed. The Bosch 4218 plugs are a taper fit. The Bosch was looked up at one of the local part stores. ( They maybe wrong) Are you saying you can remove the gasket on the NGK plug and get it to seal in a taper fit hole. I don't think this in correct.
Is my 67 head a taper fit or gasket fit type. I do have plug tubes.
PostPosted: Wed Jul 12, 2006 9:33 am
The taper fit plugs came in later years. I don't know when it began, but my son's '74 has the "drool" tubes, so it was after that.
Jerry
PostPosted: Wed Jul 12, 2006 9:56 am
This chart shows the plug and other head changes.
http://www.slantsix.org/articles/parts-matrix/jpg.htm
Also, read this thread:
http://www.slantsix.org/forum/viewtopic ... tolite+985
PostPosted: Wed Jul 12, 2006 12:27 pm
The cut off year is 1974, 75 and up use the taper seat and can't use the 985's or ZFR5n's :x . I had a 2.5L ram van that I managed to find Pontiac spark plugs that fit that had a longer head so there might be something else out there for later heads.
PostPosted: Wed Jul 12, 2006 1:45 pm
I used the ZFR5N plugs. These are the plugs that where removed. (Autolite platuim) #2 and #6 look a bit different than the others. This motor has either 22,000 miles or 122,000 miles. (odometer rollover?) Your thoughts on the plugs.
http://www.renaissanceracing.com/images ... gsfull.JPG
PostPosted: Wed Jul 12, 2006 1:47 pm
Oh and where do I get new plug tube O-rings?
PostPosted: Wed Jul 12, 2006 2:48 pm
Fel-pro ES12794
Autozone
Got mine @ a year ago
PostPosted: Wed Jul 12, 2006 3:14 pm
Looks like your engine is running a little on the lean side. What is your timing set at? They are supposed to be a light tan color.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Wed Jul 12, 2006 8:54 pm
have not checked timing. I have noticed a ping around 60 - 70 mph under light acel, but goes away as more gas is given. Running a 185 degree thermostat.
Users browsing this forum: Bing [Bot] and 5 guests
