It is currently Sat Jun 06, 2026 8:02 am
 Post subject: Motor Mount
PostPosted: Thu Jul 13, 2006 4:57 am
Does anyone have a source for the right side motor mount for my 63 Valiant /6? I got the drivers side from Advanced Auto, but no one seems to have the right side. Mine has deteriorated and has separated. Thanks.
PostPosted: Thu Jul 13, 2006 7:34 am
Pat, I had the same thing happen. Advance had the left but not the right. Somehow we started looking in to it and found that the book had a bad #.
We looked at similar #s and it was one digit off, if I remember correctly. I think I have the box ends somewhere. I'll look and reply if I can find them.
 Post subject: Re: Motor Mount
I sure had problems with motor mounts recently. A friend of mine works at an auto repair and has a press, I ordered just the inserts. One insert(the right), was fine and pressed in. The left however wasn't quite right, but fit. He went ahead and pressed in the left one so I could install my engine and ordered another insert. Since the left is easy to get to, I thought I would just get a better one later and replace it.
Anyway, he got about four or five of them, all wrong, all the same part number from diffferent sources. I then ordered a complete left side motor mount from Kragen (partsamerica). When it came in, it looked like a cassette that had been sitting on a dashboard in the Sun. I couldn't believe it, it was all warped and one of the mounting holes was a big oblong shape. Not made in China, but India.
So, I still need to get a left side. Maybe I will try Advance Auto. I would like to get a quality one made in the USA though.
PostPosted: Thu Jul 13, 2006 7:50 am
I would appreciate that Larry.
RDJ, Advance had to order it and it took about 5 days and the cost was about $25. FYI
PostPosted: Thu Jul 13, 2006 8:23 am
R/H mounts are no longer available in the aftermarket. L/H mounts will soon "dry up", as well. Anchor numbers were 2303 L/H and 2304 R/H. BUT!
Imperial Services is in final stages of tooling for really nice polyurethane left and right mounts, made in America, with internal lock plates, for '62-'66 A-bodies with slant-6s! Just got off the phone with Steve over there, and it surely sounds as if these are going to be the excellent-quality upgrade mount we've been after for quite a few years for these cars. That's the good news. The bad news is that in all likelihood they won't be shipping until 1/07, so until that time you'll have to figure out something to get by. You can probably make fit an Anchor 2264 mount ($5 cheapie from Malaysia, buy from RockAuto or your local source), that is the R/H mount for '67-'72 A-bodies. You may have to cut off one of the three studs ('62-'66 mount has only two studs) and depending on comparative thickness of the mounts, you may need to shim the 2264 with some plywood or other suitable material.
DS
PostPosted: Thu Jul 13, 2006 8:53 am
FYI - you can already get the left mount in poly. Or if you are blessed and have a truck that uses the same mounts on both sides (same as a small block V8 ) you can get both left & right mounts. :?
http://www.polybushings.com/pages/2469.html
I have a set (not yet installed) and they look to be very nicely constructed pieces.
-S/6
PostPosted: Thu Jul 13, 2006 9:05 am
Mmmmmnope! Not suitable for the RH side of any slant-6 A-body, and not designed for the '62-'66 A-body (as needed). That's a '67-'72 A-body LH-side mount (also fits other applications due to "adaptive" construction).
PostPosted: Thu Jul 13, 2006 9:32 am
Whoops...I read the '67-72 in the latter part of your original post, and missed the '62-'66 part. :oops:
I must need glasses.... :lol:
PostPosted: Thu Jul 13, 2006 9:41 am
Since this is a stock engine w/auto and I have no fan shroud or anything that would break if the engine moves a little, I'll wait for Imperial. I put them on my "favorites" list and I'll bug them from time to time to keep the interest up. If it gets worse I can always resort to a chain and turnbuckle, I guess.
Thanks for the info.
PostPosted: Thu Jul 13, 2006 11:09 am
Back in May, The Paddock, said they still had them available. EM2303 and EM2304, cost was 17.95 ea plus shippibng.
PostPosted: Thu Jul 13, 2006 11:58 am
Thanks Charlie. I just ordered one from Paddock. We'll see what happens.
STANDARD OE MOTOR MOUNT
FITS 62-66 A-BODY 170, 225, RH.
Product Number EM2304
Price:$17.95
Quantity:
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 4 guests
