It is currently Mon Nov 23, 2026 7:10 am
Post new topic  Reply to topic  [ 38 posts ]  Go to page Previous 1 2 3
PostPosted: Thu Jul 13, 2006 12:23 pm
So which mount do I use when I swap my 77 engine into my 66 (with 64 front sheetmetal)?
PostPosted: Thu Jul 13, 2006 12:59 pm
You use the '62-'66 mount setup complete (engine brackets + insulators). The '77 parts won't even come close to fitting. You'll also need the '62-'66 oil pan and pickup tube, and if you have an automatic transmission, you'll need the 1/8" annular adaptor ring for the rear of the crankshaft.
PostPosted: Thu Jul 13, 2006 1:02 pm
Thanks Dan. Re: oil pan. If I have the V8 centerlink I don't need to swap do I?
PostPosted: Thu Jul 13, 2006 1:03 pm
You need the engine brackets and rubber insulators (mounts) for a 63-66 "A" body slant six.
You will also need the oil pan and pickup for the 66 down engine.
If you use the 66 trans, you will need an adapter bushing in the end of the crank, and the 77 flex plate.
PostPosted: Thu Jul 13, 2006 1:08 pm
The '73-up spool-type mounts likewise do a better job restraining the engine....
Which is one of the reasons why I did this...
As an added bonus, I get the through bolt idler (the reason I first started down this road) and I hope to be able to use the later swaybars as well.
Haven't fitted it yet, so it may not be a success, but I feel pretty confident.
'15 Chrysler 200S V6
PostPosted: Thu Jul 13, 2006 1:29 pm
You're welcome. Yes, you still need to do the swap, even w/V8 centrelink. The later pan hits the early K-frame because the sump is located differently.
 Post subject: slant 6 mounts
PostPosted: Thu Jul 13, 2006 3:45 pm
How much do you think you can make them for?
PostPosted: Mon Feb 19, 2007 3:44 pm
Anyone bought upgraded early 60's front motor mounts yet since the original projection for availability was Jan07 :?:
