It is currently Mon Sep 07, 2026 12:55 am
PostPosted: Thu Jul 13, 2006 2:17 pm
below is a picture of the last primary of my header (closest to the firewall) and to the right of it is a hole with a screw hole above it. could someone tell me what that is???
1975 Dart Swinger 225 2bbl
 Post subject: Plug it up..
PostPosted: Thu Jul 13, 2006 2:50 pm
You need to plug that up, it's the hole for the tube that goes from the AIR/"smog pump" in late heads (or in some late applications it just may have a charge tube hooked into the air cleaner). In this case, your exhaust is open to your firewall, plug with a cap, remnant of an old setup, thread and plug...
-D.idiot
PostPosted: Thu Jul 13, 2006 3:25 pm
and i guess that would be the source of that annoying tapping sound :shock: wow
p.s. thanx
