It is currently Sat Jun 20, 2026 4:55 pm
PostPosted: Sat Jul 15, 2006 11:58 am
I went to the junkyard today looking for cable type gas pedals. there were only two slant six cars in the whole yard. a 69 dart and a 73 Aspen? it was big had 4 doors pretty bad shape. anyway. both these cars had their gas pedals and both were the same. except one had a shorter foot pad so I grabbed that. has anyone used this style pedal for the swap or should I keep searching for the V8 pedal. I'm not afraid of fabbing up a way to mount it. I just dont want to put/or leave alot of holes in my firewall
64' Valiant Signet 5.9, 64' Dart 170 moredoor 3.7, 67' A100 3.7, 00' Dakota SLT 4.7
PostPosted: Sat Jul 15, 2006 12:36 pm
I am assuming that you are wanting to mount a hanging style cable throttle system on a 64 a-body. I did this on a 64 valiant I used to own. All you have to do is drill three holes in the firewall. One for the cable and two for the pedal bracket. If you look close you will even see the dimple on the firewall whihc the factory put there for the cable operated throttle linkage in V-8 cars. You can use that dimple as the hole for the cable and then just drill some holes for the pedal bracket.
PostPosted: Sat Jul 15, 2006 1:27 pm
I'd like to keep it factory and use the 64 V8 style. however. I have the hanging style pedal so I might do that.
PostPosted: Sat Jul 15, 2006 1:34 pm
Good luck finding a 64-66 a-body throttle cable linkage. You will need to get one from a v-8 car or a slant six with air conditioning. Scout for wagons, cudas, and dart gts.
PostPosted: Sat Jul 15, 2006 4:40 pm
Car Model: 1974 W100; 72 Dart
might try
www.drmopar.com
they seem to have a few of the cars with the desired parts. i haven't dealt with them, but i am sure i will as they are just up the road from me....
sb
Users browsing this forum: Chris6064, Google [Bot] and 3 guests
