It is currently Fri Nov 20, 2026 2:55 am
PostPosted: Thu Jul 20, 2006 3:05 pm
Is either a 4.30 or 4.56 ring and pinion available for the 741 casting 8.75 rear? Most of the deep ratios I spot are for the 489 casting....
PostPosted: Thu Jul 20, 2006 3:14 pm
The only aftermarket ratios I've seen for the 741 case are 3.55 and 3.73 at Randy's.
70 Dart, 360, 727
PostPosted: Fri Jul 21, 2006 12:56 am
You'll be a lot better off picking up a 489 3rd member. I got a 3.23 open one at a local self-serve yard for $50 recently. I just wish I could have found some 3.55s, but 3.23s are ok too and I didn't have 3.23s either.
PostPosted: Mon Jul 24, 2006 5:08 pm
SSRN National Champion
Fetherduster76 find a 742open or 489 open out of a b bodycar they should be cheep. Ask for a 66 and up. Then your gear slection is what you want. Thanks Ron Parker :D
It Aint Over Until I Win
Users browsing this forum: Google [Bot] and 7 guests
