It is currently Fri May 22, 2026 11:12 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
 Post subject: drags
PostPosted: Wed Oct 31, 2001 5:35 pm
just wanted to let you know that I will be at cecil county dragway this sunday.
I got my car to pull with out breaking up today, at leased thru 1st and 2nd. Its at 7lbs of boost and I was able to open up the seconderies finally. I hope to get a 14 sec run but we will see!!!!
andrew wagner
 Post subject: Re: drags
PostPosted: Wed Oct 31, 2001 7:13 pm
: just wanted to let you know that I will be at
: cecil county dragway this sunday.
: I got my car to pull with out breaking up
: today, at leased thru 1st and 2nd. Its at
: 7lbs of boost and I was able to open up the
: seconderies finally. I hope to get a 14 sec
: run but we will see!!!!
: andrew wagner
Good Luck Andrew!!!!
slantzilla@excite.com
 Post subject: Re: Off to the Drags
PostPosted: Wed Oct 31, 2001 7:20 pm
: andrew wagner
What did you adjust to get it to run better? Did you just cut-back on the boost??
Well, give 'em hell at the track and let us know how it goes.
PostPosted: Thu Nov 01, 2001 2:09 pm
I got the bigger turbo. .63a/r insteed ofthe.42a/r one I had. A 600 cfm dp holley so I can use the secondaries. I have 73 jets in the primaries and 78 jets in the secondaries. I mite go to 76 in the primaries before this week end. and straight thru exhaust. on muffler!!
andrew wagner
p.s. I mite be at masion dixson on saturday!
: What did you adjust to get it to run better?
: Did you just cut-back on the boost??
: Well, give 'em hell at the track and let us
: know how it goes.
: DD
