It is currently Sun Oct 11, 2026 7:01 am
PostPosted: Sat Jul 22, 2006 4:11 pm
Greetings -
The FSMs that I ordered, and which might or might not include the
info. that I need, won't be here for several days. In the meantime,
I'm ISO what other BBD /6rs use to 'lightly lubricate the cup' that will not react with fuel or the cup composition. If anything.
Thanks and regards.
PostPosted: Sat Jul 22, 2006 4:16 pm
Gasoline.
PostPosted: Sat Jul 22, 2006 6:00 pm
Oil of most any type you've got (engine oil, trans fluid, P/S fluid, 3-in-One) will do fine to soften up the leather so you can flare-out the cup prior to its installation. Gasoline, carburetor cleaner, brake cleaner, penetrating oil, WD40, etc. isn't what is wanted.
PostPosted: Sat Jul 22, 2006 6:02 pm
Oh. I thought he was talking about lube for inital carb assembly. Sorry. :oops:
Users browsing this forum: Bing [Bot] and 13 guests
