It is currently Wed Oct 14, 2026 5:42 am
PostPosted: Sun Jul 23, 2006 10:46 am
I have an offenhauser single quad intake manifold that I'm putting into a '73 Dart. The car has an automatic transmission and Summit Racing mentions a special kit for automatics which must be ordered separately.
What part number is this kit and is there someplace I can get a good price on it?
I also have to replace the exhaust manifold. Should I go with a stock replacement? I don't think I have room for headers with the stuff for the power steering and automatic transmission in the way.
The engine is bored .030 and it also has a comp cams cam.
PostPosted: Sun Jul 23, 2006 12:57 pm
Car Model: 1974 W100; 72 Dart
the part # you need is 5270-A. check here:
www.offyparts.com
or type that # in over at summit.
if you want a replacement (new) manifold go here:
http://www.1aauto.com/1A/ExhaustManifolds/Dodge/Aspen
its a really nice piece and even comes with new triangle washers.
in that car there is no reason not to use Dutra Duals, even with power steering....if i am thinking right.
http://www.slantsix.org/articles/exhaus ... d-mods.htm
that seems daunting at first, but once you cut the front leg off, you can braze it together with stuff you can buy at home depot.
sb
