It is currently Fri Nov 20, 2026 7:20 am
 Post subject: ride height enomaly
PostPosted: Sun Jul 23, 2006 8:23 pm
If you followed my "parts are time to get cracken thread" you know I just rebuilt my front suspension. I couldn't resist taking it out for an extended test drive this afternoon, even though it hadn't been aligned. it handles 400% better even with the alignment off and no sway bar, yet. it rides 200% better even though it sits a 1/4 of an inch off the bump stops!!! and doesn't feel as though it bottoms out. I'm running .890 torsion bars. the stance of the car is now perfect. but I dont understand how the car doesn't bottom out riding so close to the bump stops. I think the ride quality is much better. any thoughts?
I wish I knew how to post my before and after pics. (I'll try but I warn you they are high res.)
64' Valiant Signet 5.9, 64' Dart 170 moredoor 3.7, 67' A100 3.7, 00' Dakota SLT 4.7
PostPosted: Sun Jul 23, 2006 8:43 pm
Depends where the bumpstops are in relationship to the wheels and A-arm pivots.......
If the bumpstops are next to the wheels, 1/4" would be your suspension travel before contact.
If the bumpstops are halfway between the wheel and the A-arm pivot then 1/4" till bumpstop contact would be 1/2" at the wheel.....
So, you do the math and you can figure out how much wheel movement there is when there is 1/4" movement at the bumpstop.
PostPosted: Sun Jul 23, 2006 9:15 pm
they're pretty close to the pivot. so I guess that would give 1/2" to 3/4" travel. never thought of it like that. thanks Ed.
