It is currently Fri Nov 20, 2026 3:27 am
 Post subject: TIRES&RIMS
PostPosted: Mon Jul 24, 2006 1:33 pm
I want to put new rims on my 73 Duster will 14" X 7" 5-lug with 4.5" to 4.75" bolt circle fit my car T still the origanl drums on it do I need to change drums?
PostPosted: Mon Jul 24, 2006 1:53 pm
They should fit fine.
VM
 Post subject: Nope...
PostPosted: Mon Jul 24, 2006 2:51 pm
If your car has drum brakes all around you need the 5 lugs on 4" bolt circle rims (not much choice there), if you have Disc brakes you need the 5 lugs on 4.5" rims to make that work.
Good luck,
