It is currently Mon Nov 09, 2026 5:41 am
Post new topic  Reply to topic  [ 35 posts ]  Go to page Previous 1 2 3
PostPosted: Mon Jul 24, 2006 4:32 am
- Power Plate (no longer available) = 44.7 best, 38 average
Mike
My 2500 lb. 2007 Honda Fit with its 5-spd. manual and 4 cylinder 1.5 L barely averages 38 mpg in city/hwy. combined sensible driving after 6500 miles.
Go figure.
PostPosted: Tue Jul 25, 2006 7:43 am
Right now I'm feeling like one of those so-and-so's that come and post something tantilizing then you never hear from them again. Honestly, I just got caught up with some work and hadn't had time to check back in.
Here are pictures of the brochure from back when he was actively marketing the Power Plates. I tried to make them big enough to read, yet small enough to load.
http://powrehaus.com/index.php?option=c ... 5&PageNo=1
As for the screen, the one pictured I'm guessing would be just fine. I used 2 of the thick gaskets and one of the thin ones. The 2 thick gaskets spaced the bottom of the throttle plates away from the screen, and the thin one was the lower gasket. From manifold, thin gasket -- screen -- thick gasket -- thick gasket -- carb. My screen had a dish in it to simulate the angle I mentioned in a previous post.
I'm currently working on a home-made Power Plate for an '83 Ford 460 powered motor home. I'm just modifying the EGR plate by boring the primaries out larger in a step, then machining an aluminum insert (X2) for the bores. I will be eventually posting an article on that at www.FuelEconomyTips.com if you want to check in in about a week or 2.
Mike
Recognized by US Federal Courts as a Fuel Economy Expert!
PostPosted: Tue Jul 25, 2006 1:41 pm
83 Ram D150 Lean burn removed and replaced with points. Carter BBD replaced with a suprisingly good reman. A833OD Transmission. Everything else stock. Manifold leak around runner #5. From about 4 tank fills, mileage varies between 17.5 and 18 mpg.
The Old Goat '83 D150 225-2
AKA Ice Titan
PostPosted: Tue Jul 25, 2006 6:18 pm
i just figured out mine today an im getting around 19.5 with a stock 1975 duster /6 2bbl. conversion 904 2.76 rear
1975 Plymouth Duster,225/6 2bbl. and duels, 904, 7 1/4
1986 Dodge Charger Shelby, 2.2 Turbo I, A525
PostPosted: Thu Aug 03, 2006 6:02 pm
:D
Got the fuel mileage down to 11.2 MPG!
:shock:
OK, went a couple jet sizes too far. Back to the 51's.
But Ooooooh the power! :twisted:
:wink:
Users browsing this forum: Amazon [Bot] and 1 guest
