It is currently Tue May 19, 2026 6:48 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
 Post subject: 64 dart guages
PostPosted: Mon Nov 05, 2001 10:01 am
The temp gauge on my recently purchased 64 dart (225) doiesn't work. I tried grounding out the wire at trhe sending unit but nothing happens. The fuel gauge is also permanently set at 1/4 full. The speedometer also doesn't work! I need a jpicture of the under dash wiring cause It has been raped, and any other advice I could get. thanks darters...Bill
PostPosted: Mon Nov 05, 2001 9:21 pm
: The temp gauge on my recently purchased 64 Dart
: (225) doesn't work. I tried grounding out
: the wire at the sending unit but nothing
: happens. The fuel gauge is also permanently
: set at 1/4 full. The speedometer also
: doesn't work! I need a picture of the under
: dash wiring because It has been raped, and any
: other advice I could get. thanks
: Slanters...Bill
Here it the wiring diagram, (see the link, it is a big file, print it out for better reading)
Sounds like you already reviewed the posts below, you should test the fuel gauge the same way, go back to the gas tank, un-plug the wire and ground it, let us know if you get any gas gauge movement.
As for the speedo-no-worko, the wiring dia. won't help this, it is all mechanical. Reach-up under the dash and unscrew the speedo cable from the back of the speedometer "head". Once it is off, pull down the cable and see if you can pull-out the center cable "core". Also reach-up and see if the "socket" on the the back of the speedo spins with no resistance.
Here is the link and the color chart for the wires:
64 Dart Under Dash Wiring Diagram
PostPosted: Wed Nov 07, 2001 1:42 pm
HEY BILL, WOULD YOU BE FROM CALIFORNIA, AS IN CAPTAIN BILL YOUNG 5C?
YORIKC@AOL.COM
 Post subject: Re: 64 dart guages
PostPosted: Fri Nov 23, 2001 10:56 am
: The temp gauge on my recently purchased 64 dart
: (225) doiesn't work. I tried grounding out
: the wire at trhe sending unit but nothing
: doesn't work! I need a jpicture of the under
: dash wiring cause It has been raped, and any
: darters...Bill
Sounds like you need my gauge fix. See the articles section.
Chuck
webmaster@omnipages.com
Users browsing this forum: Bing [Bot] and 10 guests
