It is currently Mon Dec 29, 2025 9:02 pm
Post new topic  Reply to topic  [ 26 posts ]  Go to page Previous 1 2
PostPosted: Sun Jul 23, 2006 7:18 pm
One more thing,am I supposed to shave off those "nubs" on the back of the hei module,to allow it to sit flat? or does it matter?
I think I found a better place to mount it,on the underhood part of the right fender,where the jack tools used to be stored.
Nick
1987 Dodge D-100(225/904) Daily Driver
1979 Dodge Ramcharger (318/727/NP208)(Under Construction)
PostPosted: Sun Jul 23, 2006 7:50 pm
Those nubs might be preventing the unit form grounding since it grounds on the back of the unit.
PostPosted: Sun Jul 23, 2006 8:27 pm
Most of the HEI modules have a rivet on at least one of the bolt holes that will allow them to ground even if the rear metal plate isn't making a solid ground, but that rear metal plate is intended as a ground and, more importantly, the rear metal plate needs to be in solid contact with a heat sink (piece of aluminum and fender), and you need to use the heat-conductive grease that comes with a new module between that back plate and the mounting surface, otherwise the module will heat up and burn out.
PostPosted: Sun Jul 23, 2006 8:39 pm
Oh,at first I was under the impression that the metal parts in each screw hole were the ground. OK, so I guess I'm removing those nubs. As for the heat sink,is that similar to dielectric grease?
Nick
PostPosted: Sun Jul 23, 2006 9:13 pm
No, it's different, not the same as dielectric grease. See Here or here.
Did you run a ground wire to the ground grommet on the module, or are you relying on sheetmetal for ground?
PostPosted: Thu Jul 27, 2006 5:36 pm
Man,finding heat sink around here is proving to be a chore... I tried two auto parts places and both only had dielectric. I'll probably end up ordering it from one of those sites.
Nick
PostPosted: Thu Jul 27, 2006 5:50 pm
Try Radio Shack (or equivalent)
PostPosted: Thu Jul 27, 2006 6:40 pm
I was thinking maybe they'd have it,I'll have to stop in one tomorrow during my lunch break,if there's one nearby...
Nick
PostPosted: Thu Jul 27, 2006 6:50 pm
Heat Sink Grease
276-1372
$1.99
PostPosted: Fri Jul 28, 2006 4:58 pm
Yes,I found one this morning and got myself a tube of it. Now hopefully this weekend I can finally get this swap done....
Nick
PostPosted: Sun Jul 30, 2006 7:05 pm
For future reference, Borg Warner actually sells heatsink compound in little one use packets, I believe the part number is something like CL6 (but don't quote me on that.) It should be referenced in their catalog when you look up the HEI module. I would assume other ignition component manufacturers do the same.
Used to own:
'82 Dodge D150
Erson 270 Cam, O/S valves, mild port work, ~9.5:1 compression
Currently fighting with an '85 VW Cabriolet
My other passion
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 2 guests
