It is currently Wed Apr 29, 2026 10:46 pm
PostPosted: Mon Apr 10, 2006 12:07 pm
Another thread made me wonder....how fast can you go with a Super 6?
I know Dennis used a 2 barrel for a long time and if I recall Charlie went fast with a 1 barrel....and pmarvetz posted some quick times...
PostPosted: Mon Apr 10, 2006 12:15 pm
The best I ever did with the BBD was 16.34@82mph oh look its in my sig :roll:
PostPosted: Mon Apr 10, 2006 3:37 pm
IIRC, I went mid 16's with a BBD too. :shock:
Seymour has run high 13's, but he uses a 2bbl Holley 500. :shock:
PostPosted: Mon Apr 10, 2006 4:08 pm
The fastest I went with a 500 holley 2 bbl, was 16.14 (motor only), 13.16 on spray. I did go 16.4's with a 1bbl, in a lighter car. All with a 170 motor.
 Post subject: Bbd
PostPosted: Mon Apr 10, 2006 6:00 pm
16.7 @ 81 with BBD and log exhaust manifold, removed choke, stock converter, stock trans, probably could have gotten 15's with more work, went to 4bbl instead, (still have stock trans/conv it's my weak link wicked)
PostPosted: Wed Apr 12, 2006 10:59 pm
I wen't a best of 16.43@80.94 in Medicine Hat. Elevation is 2415 ft. on start line. The time slip shows the corrected altitude to be 3722 ft. on that run. This was with a BBD carb in my 80 Aspen which weighed 3567 lbs at the time.
 Post subject: Re: Bbd
PostPosted: Sat Apr 29, 2006 5:57 pm
Car Model: 1964 Dart GT
Thropar, Just out of curiosoty, have you run a 1/4 mi. with the 4 bbl and what was your time?
PostPosted: Sun Apr 30, 2006 3:29 am
16,087/88,27mph. That is with ´65 Valiant, 225+A833+2,76 rear without suregrip.
 Post subject: Fastest 2 barrel time
PostPosted: Sun Jul 30, 2006 7:21 am
Car Model: 69 Valiant
I know I'm way late throwing my 2 cents worth in on this. I don't get to look at the site too much anymore.
My best time with the BBD on my 69 Valiant was 15.40 @ 86mph. Mostly stock engine, headers, cam, cast iron manifold, 3.91 gear.
Best time is 15.20 with 2 barrel holley from a 360 or 400 mopar.
Joel
PostPosted: Sun Jul 30, 2006 8:47 am
Joel: that is a grrreat time slip for your set up!
AndyZ: I have run my 4bbl 15.7 @ 87, it needs a converter baaaad, the trans is totally stock, it also needs more valve spring with my cam, I'm running stock springs right now. Another thing is my alignment, it's way off...........excuses excuses!
PostPosted: Sun Jul 30, 2006 9:17 am
I have seen Joel's car and raced him many times. The car runs exceptionally well for what is in it. :D
You gonna be at RT66 or Monster Mopar Joel? :shock:
 Post subject: 2 bbl. time
PostPosted: Mon Jul 31, 2006 4:30 pm
I will be at Monster Mopar this year. Just sent off my entry fee. Sorry I can't make it to Rt. 66. My wife and I have our anniversary and my daughters bithday fall on that weekend so that one is out.
Joel
PostPosted: Sun Aug 20, 2006 9:38 am
hey sandy, the duster with a bbd ran in the 14.30s @ 90mph and with a 500cfm holley and clifford intake ran 13.87 @ 94 and won the last bracket race of the year at pacifice raceways. I'm currently running 4.56 gears with a 28in tire but plan on trying some 30 inchers to see if it picks up any on the top end. do you ever get to mission?
PostPosted: Sun Aug 20, 2006 12:04 pm
Wow that is good,,,,
I go past Mission .....but it is 8 hours from home. I will actually be there late tomorrow and tuesday doing deliveries.
I was going to bring my Valaint to mission in early July but work got in the way.
I need a new rear diff before I go to a sticky track because my 7.25 is on its way out and I have a lot more HP available than I used to.
I plan on an Explorer 8.8 or Grand Cherokee dana 35 because of available gears and limited slip. I kinda like the dana 35 with the aluminum carrier and smallish discs.
Id also like to get my 490 CFM throttle body injection on before racing cuz I think I get pretty lean with the BBD on the top end.
Be fun to hook up sometime....
PostPosted: Sun Aug 20, 2006 3:51 pm
maybe I'll see you at ashcroft next year then. how do the explorer and jeep rears measure up for overall width?
