It is currently Thu Nov 19, 2026 5:35 pm
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Tue Aug 01, 2006 10:08 am
The spindles are "wrong" for the application, but they will bolt in with the '73-'76 upper and lower ball joints. There's some controversy over whether the cars handle better on stock spindles or the later, taller spindles as the geometry is different. However, it seems that if there is a difference, it'd only show up in autocrossing or road racing.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Tue Aug 01, 2006 10:12 am
Yeah, that's what I have read as well. I have the 74 A body spindles anway. I've heard the rotors and calipers swap, and I should save the brake lines (brand new).
PostPosted: Tue Aug 01, 2006 6:56 pm
I am using the 5th Avenue Disc Brake assy and Spindle. That spindle is designed for a lower ball joint (actually just a lower knuckle as the lower ball joint is IN the lower control arm on those) that is THREADED where the 2 bolts attach it. I use the early to mid 70's A-Body lower ball joint which is NOT threaded. I then use 2 Truck Frame Grade 5/8" bolts fastened with a self prevailing/locking nut, NOT A NYLOK NUT.
NOTE: There is a pair of A-Body late upper A-Arms, with the large Ball joint, on Moparts.com for $100 :)
Terry
Terry Bogusz
From Super 6 Left turns to Straight again.
PostPosted: Tue Aug 01, 2006 7:02 pm
Never heard the term. What does it refer to?
PostPosted: Tue Aug 01, 2006 7:07 pm
:D
Dan ol' buddy ol' pal......
The nut I described is one where the crown is peened over or semi closed, to act as a lock mechanism. They are one time use though. Remove one and throw it away.
The bolt used with these may only be used twice (at the most) before the threads are ruined by this crimp.
These are standard USDOT approved fasteners for Truck frames and attachments.
The Hacker :wink:
LOL
Terry Bogusz
