It is currently Fri Nov 06, 2026 12:41 am
Post new topic  Reply to topic  [ 36 posts ]  Go to page Previous 1 2 3
PostPosted: Fri Aug 04, 2006 4:28 am
Do you think this is caused by the short rod ratio or maybe the high CR and your getting detonation?
PostPosted: Fri Aug 04, 2006 7:51 am
I did the same thing to one with nitrous. I would guess detonation. I also split the piston in two. :shock:
PostPosted: Fri Aug 04, 2006 7:59 am
I thought the 2.2L piston was a very strong one. Maybe is just a strong one compaired to it weight.
PostPosted: Fri Aug 04, 2006 2:56 pm
Hyperteutectic are stronger than cast, but are supposedly brittle. I raised the top ring lad on 3 other pistons besides the one that let go. It was from being too rich on fuel when spraying. :shock:
PostPosted: Fri Aug 04, 2006 3:14 pm
My understanding is that too lean is the bad one when on spray. (I know very little about nitrous though)
Stock piston is cast Aluminium? (weakest cheapest)?
The 2.2L pistons are hypereutectic silicon and AL (stronger more costly)?
Forged piston are steel? (strongest, heavy,costly)?
Does this sound right.
If you were to have a custom piston made for a low rev engine that can handle lots of nitrous, what would the piston material be?
Don't concider cost unless its Nasa priced.
PostPosted: Fri Aug 04, 2006 5:33 pm
What few people realize is that too rich on fuel is almost as bad as too rich on nitrous. Rich on fuel cuts power, but lifts the top ring land, even on forged pistons.
Forged pistons are aluminum. They are just machined from a forged blank instean of a casting.
Users browsing this forum: Ahrefs [Bot] and 8 guests
