It is currently Sat Nov 14, 2026 1:24 am
PostPosted: Sat Aug 05, 2006 4:19 am
Are there any hints on the best way to remove the spring clip to get the governor off the shaft of my electronic Distributor?. I'm not have any luck. I can get a hold of it a little with snap ring pliers but can"t get it off.
Rick
PostPosted: Sat Aug 05, 2006 4:32 am
Are you talking about the little wire clip that's on the shaft?
It's a pain, I used needle nose pliers.
See this for some other ideas on it.
http://www.slantsix.org/forum/viewtopic.php?t=18448
 Post subject: That's the one
PostPosted: Sat Aug 05, 2006 4:50 pm
Yes the little clip down inside. I tried again today for about a half hour and no luck. I need to get this one apart to weld up the governor or else I need another distributor with a governor with less advance. Somewhere around 10 (20 actual) would be good. From what everyones saying the slant likes less than 30 degrees and with our initial at 8-10 we would at about 40 degrees with the 15R that is currently in the distributor. Anyone got one for sale?
Rick
PostPosted: Sat Aug 05, 2006 5:05 pm
Don't worry about bending it, just get some needle nose pliers on it and yank............
A small screwdriver on 1-leg and the needle-nose pliers on the other leg may help by spreading it apart a little
 Post subject: Not yet but soon...
PostPosted: Sat Aug 05, 2006 6:24 pm
I have taken a bunch of 15R's (about 6) over to my buddy's house and we welded them up. I need to clean them up, and file the slots (they are closer to a 6R now... :roll: )
I'm going to finish them as a 9-10R (depends on that last couple thousands).
I may have a couple of them ready by the end of the week...
 Post subject: Re: Not yet but soon...
PostPosted: Sat Aug 05, 2006 6:52 pm
That's not going to do him any good if he can't get the old one off...............
:twisted: :? :roll:
PostPosted: Sat Aug 05, 2006 9:26 pm
Rick,
keep a steady downward pull on the shaft as you spread the tangs, one at a time, with a small screwdriver. The downward pull of the shaft will make the groove in the shaft help wedge the clip, keeping it expanded as you work at spreading the tangs.
Slant Cecil
 Post subject: Thanks
PostPosted: Sun Aug 06, 2006 10:39 am
Thanks, I'll give that a try a little later.
Rick
PostPosted: Sun Aug 06, 2006 11:07 am
Keep your eyes open for a set of "dental" picks, too. We use them all the time on transmission stuff, and they're great (that you, Tony?) for little clips like that.
O==\=/==O
"A mechanic is Somebody."
- Jim Preston
PostPosted: Sun Aug 06, 2006 4:48 pm
I used a small pair of needlenose pliers and had my clip out in a few seconds.
82 D150-225/727
02 Dakota-3.9/5 speed
 Post subject: Got it out!
PostPosted: Mon Aug 07, 2006 7:40 pm
I tried for a while to spread the clip to get it off but there just wasn't enough room. So I took a good pair of small needle nose and gave a steady pull and it came right out. It didn't even bend up the clip much at all. Thanks for all the help.
Rick
 Post subject: Plink...
PostPosted: Mon Aug 07, 2006 8:33 pm
Some of those clips just say "oh no you don't..."
Glad you have mastered the art of hairpin wrangling! :wink:
PostPosted: Tue Aug 08, 2006 5:09 pm
And other clips say 'see you later' and are never seen again as they fly across the workshop, once released.
PostPosted: Tue Aug 08, 2006 7:32 pm
:D
Users browsing this forum: Ahrefs [Bot], DuckDuckGo [Bot], Google [Bot] and 4 guests
