It is currently Thu Apr 30, 2026 9:32 pm
 Post subject: Wierd Oil Leak
PostPosted: Sun Aug 06, 2006 7:11 pm
A few weeks ago i replaced my rear main seal and oil pan gaskets because there was oil leaking from the inspection plate, but it still leaked. So yesterday i pulled the trans, clutch, flywheel, the whole deal to replace the freeze plug. The freeze plug was good as new, so i sealed up the pipe plug and oil pan with RTV. But it still leaks just as much as before. Am i missing something or am i just a bad mechanic? It leaks through the inspection plate so its definately something on the back of the motor. I need help!
Drive it like its stolen, and be glad im not YOUR son...
PostPosted: Sun Aug 06, 2006 8:25 pm
Have you seen where the oil is coming out while the engine is running?
Pull the inspection cover, start the engine and get a bright light to see if you can spot the exact place the oil is coming out of.
Stay away from the moving flywheel. :shock:
PostPosted: Mon Aug 07, 2006 3:18 am
Is it motor oil or could it be transmissoin oil?
PostPosted: Mon Aug 07, 2006 3:53 am
You sure it's not the valve cover gasket? Don't ask me how I know. :shock:
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 1 guest
