It is currently Wed Nov 11, 2026 5:30 pm
PostPosted: Fri Jul 28, 2006 1:23 pm
I'm putting together an '83 225 out of a Dodge pickup for my '63 Valiant. The engine was originally equipped with a hydraulic cam and lifters which I have replaced with a Comp Cams 64-246-4, grind CR6 252H10 and their hyd lifters and new springs. The instructions with the cam explains how to determine the amount of pre-load on the lifters and how to compensate if it isn't correct. The rockers are non-adjustable, the pre-load turned out to be ~.100" using the method described in the pamphlet. This seems to imply that I have to shim the rocker shaft ~.070" to get the desired pre-load of .030" recommended by Comp. I called Comp and was advised to try what I have alluded to above, but since this is the first time I have tried this, I wanted to get other opinions. This is my first re-build on an engine with non-adjustable rockers. The rockers are new, but the push rods are the original ones furnished with the stock cam from the factory. Thanx for your help and consideration. RMDV.
Carl Zeamer. an old guy, please be gentle.
PostPosted: Fri Jul 28, 2006 1:36 pm
I would call Smith Brothers and get a shorter set of pushrods made. :shock:
www.pushrods.net
PostPosted: Fri Jul 28, 2006 5:07 pm
I had "very" bad luck with rocker shaft shims. I used a clifford hydraulic cam and milled the head .100". I had to use 3 .030" shims under the rocker shaft. Stupid me snugged the shaft down too tight and cracked a few of the rocker shaft perches :oops: The shims didn't fit together very well, and figured they would "squash" a little. The top edges of the shims ended up narrower then the rocker shaft and "spread" the perches apart. I didn't over do it by any means (I managed to do that with a normal box end wrench).... Anyways where I am going with this is if you end up using multiple shims make sure you trim them to fit proper!!!
 Post subject: Re: Lifter pre=load etc
PostPosted: Sun Aug 06, 2006 9:58 am
Hey Slantzilla,
Good call. I called Smith Brothers and they are making a new set of push rods for me that will accomodate the proper valve train geometry. Thanx for the help. And I was comforted to find I had measured the pre-load properly. Those guys were a great help. Hopefully I will have the 'ol Valiant back in the stop light derby. Regards. RMDV.
PostPosted: Sun Aug 06, 2006 2:48 pm
why not just use the rockers off of a mechanical cam motor? that way you can manually set the preload
1975 Plymouth Duster,225/6 2bbl. and duels, 904, 7 1/4
1986 Dodge Charger Shelby, 2.2 Turbo I, A525
PostPosted: Sun Aug 06, 2006 3:02 pm
Car Model: 1974 W100; 72 Dart
most parts stores will have a list of pushrods....all machine shops worthy of the name will. stock length is 10.009" get a 5/16 ball/ball push rod that is 9.900" and be done with it....i spent $1.50 each on mine. what is smith bros gonna charge you?
or buy a new set, use a tubing cutter and make your own.
just thinking out loud here.
sb
PostPosted: Sun Aug 06, 2006 4:47 pm
Because then he won't have oil to the lifters. There is no lifter oil galley on a slant so the hyd lifters get their oil through the valve gear and down the pushrods.
PostPosted: Mon Aug 07, 2006 8:11 am
yea i remembered that last night
