It is currently Sat Nov 14, 2026 10:07 am
PostPosted: Wed Aug 09, 2006 10:24 am
My '82 Mirada failed emissions (has to pass once in WI for Collector's Plates)...the details are:
HC: MAX Limit: 2.0 MIRADA Reading: 2.5795 - FAIL
CO: MAX Limit: 60.0 MIRADA Reading: 96.1360 - FAIL
NOX: MAX Limit: 3.0 MIRADA Reading: 2.3708 - PASS
Gas Cap - PASS
Attendant said with the numbers it posted, the carburetor is usually the culprit. It really doesn't idle too smoothly and is REALLY hard to start when the engine is warm - in fact, I was afraid it wasn't going to start (cranked and cranked - had to floor it to clear the carburetor as if it was flooded and it killed after doing that twice - finally got it started and two-footed the gas and brake and once I got it going it seemed OK the rest of the way home) after I went in and got a 30 day extension on the emissions testing.
Anyone have any ideas where I can find the correct specs so we can try to adjust it out? If that doesn't work, any recommendations for carb re-build kits?
Thanks!
Don
Don Stolfi
1959 Dodge 2-door Club Sedan
1969 Dodge Polara Convertible
1982 Dodge Mirada
2002 Chrysler Concorde Limited
