It is currently Tue May 19, 2026 1:24 am
PostPosted: Wed Aug 09, 2006 6:21 pm
Wanting to build up an 8.25 for a drag project but am wanting to know which would be better suited for the job>? SureGrip>?or Spool????
PostPosted: Wed Aug 09, 2006 7:19 pm
A spool technically requires custom alloy axles to be NHRA legal. If you ever want to drive this car on the street I would discourage you from running a spool or a locker. Heck, I wouldn't even use an 8 1/4 for a drag project, but that's mostly due to my stock of 8 3/4 third memebrs and dislike of C-clips.
Is it safe to assume you already own the 8 1/4?
PostPosted: Thu Aug 10, 2006 12:47 pm
Oh of course I already own it. 8.75 rears are hard to come by around here and due to the fact that I just cant swing the pricing for one- but maybe I'll have to bite the bullet and go with an 8 3/4. 8.25 sg=$300/
8.75 sg =500+
what to do...
PostPosted: Thu Aug 10, 2006 5:55 pm
Well, if you already own the 8 1/4 then buy the Sure-Grip and the gears you need and build it. If you really wanted or needed a spool you'd end up buying axles too and that would eat up the budget. I have a C-body 8 3/4 housing and a pair of pickup axles to have cut down for my Dart. I also have several 3rd members, two with the early type Sure-Grip. So my choice is pretty easy.
PostPosted: Thu Aug 10, 2006 6:36 pm
I do happen to have a 741 casting center chunk but I cant seem to get or find a low gear set for it . I need 4.56's. I guess the 489 is the way to go...
PostPosted: Thu Aug 10, 2006 7:23 pm
I went with a detroit locker.
Got it from randy's Ring and pinion. www.ringpinion.com
I drive the car on the street and I race it a bunch too.
No clutch packs to service and no cones to bottom out.
PostPosted: Thu Aug 10, 2006 9:42 pm
You going to warn him about the noise and harshness or should I?
PostPosted: Thu Aug 10, 2006 10:49 pm
What about a true-trac?
dont even know if they're made for this application, but I like that they have nothing to wear out.........
PostPosted: Fri Aug 11, 2006 7:49 am
Drag race only? Spool. End of discussion. :shock:
PostPosted: Sun Aug 13, 2006 5:42 pm
SSRN National Champion
Ditto ole buddy Bagle . Possum :D
It Aint Over Until I Win
PostPosted: Tue Aug 15, 2006 8:01 am
8.75 sg =500+
what to do...
Spend the money to get into an 8 3/4.
Stronger, parts are more common and easy gear changes are the first 3 good reasons to go with the 8 3/4.
Sell the 8 1/4 to help fund the 8 3/4 project.
As for a spool, don't even think about running one on the street.
