It is currently Fri May 22, 2026 12:40 pm
PostPosted: Sat Aug 12, 2006 11:47 am
What year steering linkage pieces will interchange with a 72 Satellite? Specifically, will an idler arm from a 73 Satellite work with a 72 Satellite suspension? I am not overly familiar with B-bodies, so pardon the ignorance. Thanks!
PostPosted: Sat Aug 12, 2006 12:11 pm
I believe the B body front end is the same from '65 up to '72, so any of those years will work. The '73's went to the isolated K frame and some suspension/steering pieces where changed, so I would just stay with the '72 down parts to be safe. I know larger C body tie rod ends will work and help to make the steering linkage work with less deflection.
PostPosted: Sat Aug 12, 2006 12:26 pm
Thanks! As you know, local parts stores don't stock the idler arm, so I am trolling online sources to find a good one. I have my eye on some NOS ones on e-bay. I just hope the price doesn't get too high.
PostPosted: Sat Aug 12, 2006 9:58 pm
Your local Napa shoud be able to get you one. They list an idler arm and an idler arm bushing kit on their web site. http://www.napaonline.com/masterpages/N ... PageId=100
Here is Shucks web site, looks like they have one also, but you'll have to have it ordered or order it yourself and pick it up. Done this a few times myself and never had a problem!
http://www.partsamerica.com/ProductList ... =Idler+Arm
PostPosted: Sun Aug 13, 2006 9:35 am
Hey, thanks Eric!
Users browsing this forum: Amazon [Bot] and 4 guests
