It is currently Thu May 21, 2026 3:15 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Post subject: cylinder head?
PostPosted: Wed Nov 21, 2001 9:35 pm
Ive dug out a cylinder head for my 225, done some measurements. its got 1.67 exhuast and 1.92 inlet, what mods am i gonna need to run this on my /6.
currently its got a 350 cfm holley, cain 2brrl manifold, pacemaker headers, 40 thou oversize, not to sure of cam specs, slightly modified Im told, 904 trans with stg 2 shift kit
jdosi@hotmail.com
 Post subject: Re: cylinder head?
PostPosted: Sun Nov 25, 2001 8:18 pm
intake=1.92
exhust=1.67
valves=3.59
.040 over =3.44
that would be a big notch
Will
: Ive dug out a cylinder head for my 225, done
: some measurements. its got 1.67 exhuast and
: 1.92 inlet, what mods am i gonna need to run
: this on my /6.
: currently its got a 350 cfm holley, cain 2brrl
: manifold, pacemaker headers, 40 thou
: oversize, not to sure of cam specs, slightly
: modified Im told, 904 trans with stg 2 shift
: kit
slantsix@netzero.net
PostPosted: Mon Nov 26, 2001 10:50 pm
: intake=1.92
: exhust=1.67
: valves=3.59
: .040 over =3.44
: that would need a big notch in the block
Just for ref. the biggest valves I have put into a SL6 head with-out a block side wall notch was:
Intake = 1.875
Exhaust= 1.535
I could have gone a tad bigger on the intake but the exhaust was with-in .030 of the wall. This was on a .100 overbore. (3.50) I had to sped a lot of time getting the head centered over the bores and also found that some of the valve guides were not machined at their proper locations.
I would say that most SL6 engines do not need to go super large, 1.75 Int. and 1.5 Exh. is fine
