It is currently Sun Nov 29, 2026 1:25 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
 Post subject: 7 1/4 REAR
PostPosted: Tue Nov 27, 2001 11:20 am
Does anyone have a ring gear carrier bearing adjuster on their bench or in a parts box. I need to know the size of the hex hole in the center, so i know what size nut to weld on a shaft to make a tool to loosen the bearings. I missplaced the tool i had sometime in the last 20 yrs.
Charlie
flturbo6@aol.com
 Post subject: Re: 7 1/4 REAR
PostPosted: Tue Nov 27, 2001 12:54 pm
: Does anyone have a ring gear carrier bearing
: adjuster on their bench or in a parts box. I
: need to know the size of the hex hole in the
: center, so i know what size nut to weld on a
: shaft to make a tool to loosen the bearings.
: I missplaced the tool i had sometime in the
: last 20 yrs.
: Charlie
I have used the end of a A-Body torsion bar, it fits right in. I forget the size so I will check it tonight and let you know.
I think the screw adjuster style started in 69, a lot of earlier 7 1/4 had shims to adjust the carrier position.
