It is currently Mon Nov 16, 2026 12:24 pm
PostPosted: Tue Aug 29, 2006 11:42 am
i am converting my 66 dart from the 9 inch drums to lbp disk brakes . I am stumped on the brake caliper hoses . Do i use 73-76 brake hoses? Are they going to be long enough?
Thank you for your help
PostPosted: Tue Aug 29, 2006 1:53 pm
If you're using '73-'76 A-body slider calipers mounted to the front, hoses for the same should work.
If you mount the calipers to the rear, try Volare/Aspen hoses and be careful about the bleed screw location and hose orientation/clearance. You'll need to slightly modify the hose bracket to fit the hose block.
Here are some photos from my '64 Valiant. 205-60R15's on 15X7 rims fit with 13mm offset.
Volare Calipers and hoses:
Hose End:
Bracket:
PostPosted: Tue Aug 29, 2006 5:12 pm
I mounted my calipers in the rear and used Aspen / Volare brake hoses.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Fri Sep 01, 2006 8:41 am
I went with front mount and used the 73-76 hoses on our 71 swinger just to keep it simple. I shipped all the parts and had to finish the work inside of a week away from home and we drove the car from northern Washington to southern California with a side trip to Yosemite. I would have preferred a rear mount as well. I am going to be using an addco sway bar and will find out what kind of hassle that may be soon. I have thought a little bit about putting holes in the k-member and using the 73-76 style sway bay, but it would be easier to just get new hoses and calipers and swap to rear mount. I hope it does not come to this.
Users browsing this forum: Ahrefs [Bot] and 8 guests
