It is currently Sat Nov 28, 2026 8:08 pm
 Post subject: 300 hp slant?
PostPosted: Thu Nov 29, 2001 7:57 pm
what would it take to make aprrox.300 hp from a s6? will be in an 1800 pound altered chassis drag car and alcohol fueled.and any links to similar setups would also be appreciated.thanks
karamojos7mm@yahoo.com
PostPosted: Thu Nov 29, 2001 8:51 pm
: what would it take to make aprrox.300 hp from a
: s6? will be in an 1800 pound altered chassis
: drag car and alcohol fueled.and any links to
: similar setups would also be
: appreciated.thanks
You will need lots of compression, lots of cam and lots of head work.
Drop Seymour a line and get on the SSRN mailing list. The Cox Boys, Will Burns, the Davis team and a few others are doing it. This will run fast in an 1800 lb car.
