It is currently Wed May 20, 2026 10:59 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Post subject: Intake manifold types
PostPosted: Sat Dec 01, 2001 8:16 am
I have a 64 Dart with a 225 of unknown origin in it. The intake manifold has an EGR valve on it (I think that is what it is), so I figure it is from a later model. However, there is no vacuum port in the manifold for the PCV valve, so I have to cut the carb mounting gasket to provide the vacuum. Does anyone know what combinations of PCV valve vacuum ports and EGR valve came on which year intake manifold - I'd like to get the correct one for my year, which I'm guessing has a vacuum port and does not have an EGR valve.
tomc@abac.com
PostPosted: Sat Dec 01, 2001 9:28 am
: I have a 64 Dart with a 225 of unknown origin
: in it. The intake manifold has an EGR valve
: on it (I think that is what it is), so I
: figure it is from a later model. However,
: there is no vacuum port in the manifold for
: the PCV valve, so I have to cut the carb
: mounting gasket to provide the vacuum. Does
: anyone know what combinations of PCV valve
: vacuum ports and EGR valve came on which
: year intake manifold - I'd like to get the
: correct one for my year, which I'm guessing
: has a vacuum port and does not have an EGR
: valve.
On my 65 engine the PCV connected to the base of the carb. Charlie
flturbo6@aol.com
PostPosted: Sat Dec 01, 2001 2:56 pm
: On my 65 engine the PCV connected to the base
: of the carb. Charlie
Mine is the same. THe vacuum port on the carb leads to a hole on the bottom which mates with a similar hole in the intake manifold - at least that is what I think it should do.
tomc@abac.com
