It is currently Thu May 07, 2026 11:40 pm
 Post subject: New Timing Set
PostPosted: Fri Sep 01, 2006 7:10 pm
I went to NAPA today and got a timing set and a timng cover gaket set. New timing set has all steel gears. Looks pretty sturdy.
Dot to Dot!
I will have pics of my stretched stock timing set as soon as I get it out of my car. The plastic cam gear has done started coming apart and winding up in the oil.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Fri Sep 01, 2006 7:20 pm
Do a side by side comparison of the chains so we can see the stretch..........
:twisted:
PostPosted: Fri Sep 01, 2006 7:24 pm
Betcha those teeth look like fish hooks too.
And what is behind door number 1....
82 D150-225/727
 Post subject: Funny...it's...
PostPosted: Fri Sep 01, 2006 8:22 pm
It's a reboxed "Cloyes" setup...
Make sure you watch the dot, it may be 180 degrees out (just use a longer ruler...) :wink:
 Post subject: Re: Funny...it's...
PostPosted: Sat Sep 02, 2006 6:34 am
Actually they are not 180 out. When the dots are lined up the engine is at TDC compression #6, not #1. This is as it should be. With the dots lined up #1 is at TDC overlap, and you can lay a straight edge across the valves, and they should be open the same amount (split overlap).
Users browsing this forum: No registered users and 15 guests
