It is currently Wed Nov 18, 2026 6:23 am
 Post subject: overdrive 4-speed
PostPosted: Sat Sep 02, 2006 1:03 pm
hey guys i found a 77 volare with a slant 6 for sale its a slant 6 overdrive for speed. i was wondering if i could take all the 4-speed stuff and put it into my 75 scamp the pedals hump and crossmember will it work. by the way the scamp is an automatic.
yo yo i be bill
PostPosted: Sat Sep 02, 2006 4:08 pm
You need A body pedals and hump. Most everything else will work fine. You keep your original A-body crossmember.
PostPosted: Sun Sep 03, 2006 6:13 pm
so the auto trans crossmember will work ? what about the z-bar and what needs to be done to the frame? thanks
yo yo i be bill
PostPosted: Sun Sep 03, 2006 8:57 pm
Yes, the auto trans crossmember will work.
You'll likely need an A-body Z-bar, but I'm not 100% certain. On my '66 Dart I had to bolt in the body-side Z-bar pivot and modify the bellhousing side pivot so it was higher. Since your car could have come with this trans and bellhousing you should be able to find the right bellhousing pivot if the F-body piece is different. SlantSixDan can probably help since he has a lot of factory parts books.
PostPosted: Mon Sep 04, 2006 5:34 pm
is the overdrive any good for performance on the street or is it more of a econmical and crusing transmission?
yo yo i be bill
PostPosted: Mon Sep 04, 2006 6:27 pm
Most people like the "close ratio" tranny so they don't have too many RPM drops between gears. The A-833OD is a wide ratio tranny so you have to rev up a bit to keep the rpms in the power band while upshifting (there's about a 1000-1500 rpm drop in the low 3 gears and a 500 rpm drop or so in the 3-OD shift depending on your rear gearing).
The "good" thing about the tranny is the OD gear, and it can help depending on your car's setup with either mileage, or power or both.
Currently I run the OD with a 3.55 rear gear, and it has great pickup through the bottom 3 gears, but I can shift into OD and still get good mileage during cruise mode(in essence, you can run drag gears, and still be able to afford the gas in many instances).
PostPosted: Mon Sep 04, 2006 7:01 pm
For performance the A388-OD stinks. The RPM drop between gears is pretty bad. It's just like a 3 speed plus an overdrive. I had a '66 Dart with a Comp 264° cam, 390 Holley on a Clifford intake, etc and the overdrive. Switching to a standard 4 speed was one of the best things I ever did for the car.
