It is currently Sat Nov 14, 2026 4:28 am
PostPosted: Sun Sep 10, 2006 8:41 am
I am leaking transmission fluid where the shift cable goes into the transmission.My mechanic says the only way to stop the leak is to get a new shift cable. Is this true?
PostPosted: Sun Sep 10, 2006 9:28 am
what about a new "o" ring? I'm assuming 65 & earlier push button style tranny's---
 Post subject: shift cable leak
PostPosted: Sun Sep 10, 2006 10:28 am
One would think he would have observed the condition of the o ring when he had the transmission out. All he could do, he said, was to cover the outside with silicone. It still leaks.
PostPosted: Sun Sep 10, 2006 11:02 am
The O-ring suggestion is definitely the first place to check. Also, see that you and your mechanic are clear with one another as to whether it's the shift cable or the park cable that's leaking; there is an O-ring on each, and the park cable housing also has a gasket.
If the cable jacket itself is damaged (as for instance if it fell down out of its floor pan clip and rested on the hot exhaust pipe, burning a hole in the plastic cable jacket, or if it cracked) then a repair is possible: You cut/sand away any jagged burnt parts of the plastic cable jacket, clean the cable thoroughly with brake cleaner, cut a piece of fuel injection hose (marked SAE J30R9) 3 inches longer than the damaged portion of the jacket, slit the hose lengthwise (some "spiral" to the slit helps), coat the damaged area of the cable with Mopar RTV silicone (don't substitute another brand), place the slit hose over the area and twist/shift it a little to spread the RTV, then apply hose clamps at 1½" intervals, just enough to hold the hose firmly, but not so tightly as to squeeze the cable, which would cause it to bind.
If in the end this doesn't work, replacement cables are available.
PostPosted: Sun Sep 10, 2006 1:47 pm
Thank you very much for your reply. I'll follow your suggestions.
PostPosted: Fri Feb 13, 2015 6:22 am
An innovative and wise solution to this problem dan.. best of all it is easy on the pocket book.
I dont have any cable shifted transmissions, but I find this to be a great suggestion.
